Cabrio tyre pressure
  • cmnc
    • 27
    Hi Can anybody help on tyre pressures and the tow in for the wheels.
    Re: Cabrio tyre pressure
    Tyre pressure is stated at 24psi in the build manual I believe and the toe in is 2mm + or - 1mm.
    • cmnc
      • 27
      Thanks Alan
      • djj_engineer
        • 405
        Hi Mike
        You need to check your rear tracking as well,email me.
        Derek
          • 1644
          I use 20psi all round on 205x55x16" Toyo Proxes T1R tyres. Peter.
          • gouldsborough7
            • 393
            I use 20psi all around as well quite happily throughout the year.
