dolly rear axle
  • bigalnelson
    • 1
    dolly rear axle
    having fitted the dolly axle I now need to nail it down in a better fashion.four link seems like one solution but having seen Lees set-up [or some of it] on the forum it could be a lot less hassle as axle tramp is my main concern. Any help with pictures or plans would be much appreciated main
    Re: dolly rear axle
    My experience with a tuned B series 1800 and a dolly sprint axle suggests that fitting new Superlex bushes to the leaf springs and a pair of adjustable shocks does a lot to eliminate axle movement.
    Still an interesting idea though.....
    • CosworthCabrioLee
      • 924
      Re: dolly rear axle
      Hi Alan I have a quite highly modded lotus twincam and fitting the tramp bars and panard rod is one of the best mods i have done. I can not get any tramp at all even doing silly things on dry tarmac.
      Give me a buzz and I can give you more info
        • 709
        Re: dolly rear axle
        With a B Series (untuned) & 4-speed 'box I used to get tramp on take-off...not huge but noticeable. With a T16 & Type 9 (160lb/ft torque at 2800rpm) I've not experienced any significant tramp at all (yet!).
        I can only put this down to the T9 gearbox mount, which is a lot stiffer than the stock Marina mount (allied with a reinforcing cross-member for the box). Everything else is as before...
          Re: dolly rear axle
          Perhaps Jez has a point as I also have a type 9 and stiffer gearbox mount to suit. I guess that Lee's Lotus/Ford car is also type 9 equipped.
          Perhaps thats the answer.
          • CosworthCabrioLee
            • 924
            Re: dolly rear axle
            Yeah type nine box set up, I have to have everything located tight as my tunnel is very narrow to have wide seats in
