fuel gauge
  • jsloan50
    • 23
    fuel gauge
    I have a problem with the fuel gauge of my Marina based Roadster.
    When it reads half full it is empty,can anyone help me sort?
  • CABRIOBOB
    • 478
    Re: fuel gauge
    It is a common problem with the Marina based Roadsters. I removed my sender unit and re-bent the float arm and it made it 90 per cent better.
    If you do a search on the forum you will find other ideas what other owners have done.
    • greggpearson
      • 133
      Re: fuel gauge
      Except when the 'floaty' thing comes off and 'floats' around the tank.
      All better now though, fitted a new one last month.
      Hum,bug Gregg
        Re: fuel gauge
        Didn't someone graft a Marina sender onto an Escort flange. I can't find it in Pitstop but I am sure it was published. Along with a new electronic voltage regulator, it has to be the final solution.
        Perhaps it has made the latest edition of Tech Tips.
        • lizbillings
          • 828
          Re: fuel gauge
          I had this problem with 2 Roadsters & a Berli. I just carried a can of petrol and filled tank every 120 mls shown on mileage.
          • csjcarolyn
            • 157
            Re: fuel gauge
            I fitted Triumph gauges and grafted a suitable Triumph fuel sender unit to the original Ford Escort pick up tube. Works well after I "calibrated" the unit [bent the pick up tube]
            Roger
              Re: fuel gauge
              I used a 15 ohm resistor in the circuit between the gauge and sender unit. This brings the needle down to near empty before you run out of fuel.
                Re: fuel gauge
                I also used a resistor initially but have since adjusted the gauge using the two adjusters on the rear when I made my new tank so that it reads accurate at the bottom and fair at the top.
                I have about a gallon in when the gauge is just entering the red and about 3mm off full when the tanks full.
                It was very much a trial and error job as one adjusts the zero and one the amount of movement. Can't remember which was which 'though, but if you have a play it soon becomes obvious. It helps if you have a 10volt supply and the gauge and sender set up on the bench.
