Help i am having probs finding a new one or getting mine serviced any help would be great
brake master cylinder
Tags: None
Re: brake master cylinder
Girling/Lockheed/servo/non-servo/bore size?
If you haven't tried them Powertrack Brakes are worth a shout for classic braking components.
http://www.powertrackbrakes.co.uk/
And there are a selection on eBay right now (assuming you need a Marina item).Marlin Roadster, LWB...1860 B Series + Ford Type 9
Jez it would help if i put all the info on here yep its a girling 75 its a servo type and its off a marina... thanks for the link
ebay 180625532515 looks like it then...assuming not dual circuit. Reasonably priced as well.Marlin Roadster, LWB...1860 B Series + Ford Type 9
If I recall correctly. wasnt the same single circuit Master cylinder used on Triumph Dolomites so Rimmer Brothers or other Triumph parts stockists may be able to help.
These seem to be commanding silly prices at the moment.
