My 3.9 Cabrio has alwayshad VERY heavy steering, after being built it went to marlin for setting up, TWICE, and it was still very heavy. Whilst visiting Procomp with my sons Westfield they looked at my Cabrio. And although Mark had given me every assurance that all was well with my car & set up, it now appears that this was not so.
Procomp checked caster & camber tec and thought shims would help, but calculations showed that 44mm would be required, obviously too much. Further investigation showed that when Marlin had welded the blocks for the anti roll bar, that they had marked the location of the block front, but then fixed the BACK to this point, thus meaning that the anti roll bar is 1.5 inches too far forward. No wonder fittin the thick V8 bar was such a struggle, and why the front roll bar bushes dont last.
It is going to be sorted in the near future, and I will report on what difference this makes. I report this in case there is any other member with excessively heavy handling.
Thanks Mark, as with the unsuitable drive shafts fitten on his advise, another Marlinism!!!
