Roadster Side Exit Exhaust
    My TC plans are currently being frustrated..!Despite Don's best efforts YKC are not presently able to supply a side-exit downpipe for an 1800 TC Roadster. So my question to the Forum is whether anyone can recommend an exhaust specialist they have used recently who might have a pattern for a side-exit system. Failing which does anyone have one they no longer require?
    Thanks.
    Re: Roadster Side Exit Exhaust
    Side exit header? I have a side exit exhaust on my TC and that uses a MGB cast iron manifold. The original cast item apparently flows much better than most of the replacement mild steel/stainless steel jobies as well
    If you want pictures/dimensions of the system on my car (my understanding is the silencer/connecting pipe is from YKC/Marlin) email me via www.stefancarlton.net/index.php?type=contact (or indeed just reply to one of my previous emails )
    Stefan
    • roger
      • 43
      Sorry to highjack your post Jez.
      I also urgently need a side exhaust down pipe/ or system but for a single carb 1800 manifold. If anybody has one I would be very pleased to hear from them. Roger(at)dudley100.freeserve.co.uk
        No worries Roger...
        Stefan - I have the standard MGB manifold but it's the 2-1 link to the silencer I need and which YKC are currently unable to supply.
          Desperate times call for desperate measures...maybe someone with a factory-fit TC exhaust, whose vehicle is perhaps off the road, would be prepared to lend me their downpipe for a few days to get it copied...? Obviously I'd cover any out of pocket expenses and maybe contribute a little to their beer fund...
          Roger - I could make my current SC downpipes available for you to get copied...you'd still need a manifold and silencer though. Andy Morris the former Marina OC secretary is local to me and has shedloads (literally) of Marina spares - maybe he could help you out with a manifold. Used to be AJMARINA"at"AOL.COM (or maybe AJMMARINA can't remember).
          • paulhyder
            • 141
            Hi Jez,
            just sorting exactly the same problem and have come across a great guy in Buckingham, he can manufacture anything and at a reasonable cosy his name is Graham tel no is 01280 847756, as far as manifolds etc go he could even bend you up a sporting option. Their is also a four branch tubular manifold on ebay. search exhaust manifolds.
            • roger
              • 43
              If its any help Graham Frankland 01280 847756 was also recommended to me. In the end however for my single downpipe system I used Walker exhaust parts - 1 90 deg bend and 2 45deg bends and a silencer that I already had. These are obtainable from most parts suppliers at about ?2.50 each.
