Battery/Starter Cable - Pinto
    Message originally posted by: Joe Ryan
    Can anyone advise me on the Amp. and the Sq mm Section cable that I would need to use on the above.
    Thanks for any help.
  • Malcolmsherratt
    • 17
    Re: Battery/Starter Cable - Pinto
    Where are you mounting the battery (Bonnet or boot)?
      "boot", don't you mean parcel shelf
      (sorry I'm no electrican so can't help)
        Hi Malc
        Thanks for your reply. I intend placing it against the bulk head under the bonnet in the engine bay.
        Many thanks, Joe
        • Malcolmsherratt
          • 17
          There are as always many options you pay your money and take your choice:-
          Ratings are for lengths of up to 3 mtrs multi core copper cable, a good source is a welding supply company welding cable is a very good conductor and is very flexible.
          10mm2 100amps, 16mm2 300amps, 25mm2 600 amps.
          quite frankly I would go for the 25mm2 for both live and earth leads from chassis to battery and chassis to engine / gear box.
          Hope this helps
            Hi Malc
            Thanks very much indeed for this information, I find that this will be very helpful to me in the build.
            Once again, many thanks
