Oil Gauge
  • csjcarolyn
    • 157
    Oil Gauge
    Can anyone help, I have a 1.8 Zetec engine in my Berlinetta and want to fit an oil pressure gause. My problem is where to tap into the block. I cannot go for the plug near the oil filter because something got there first. Does anyone know any other pressure points on the Zetec engine?
    Hope you can help. Roger
  • CABRIOBOB
    • 478
    Re: Oil Gauge
    Remove the oil pressure switch and fit a T piece adaptor so you can fit your pressure gauge tube and your switch.
      Re: Oil Gauge
      Touche, just suggested that on the Berlie forum
      • csjcarolyn
        • 157
        Re: Oil Gauge
        Hi Bob,
        I have already left a message for Hugh in Berlinetta messages - thanks for this and of course you are correct BUT I have now put something else near that take off and can no longer get to it without a lot of work. It would be easier if there is another blanking which blocks off the oil passages. Do you, or anyone, know of another blanking plug I can attach the oil pressure gauge to?
        Thank Roger
          Re: Oil Gauge
          Try Burton Power or Merlin Racing. They have filter sandwich plates with tappings for gauges etc.
            Re: Oil Gauge
            Hindsight is a wonderful thing but a flexible T piece (LMA from Demon Tweeks & others) is ideal for relocating the take-offs somewhere more convenient and accessible.
              Re: Oil Gauge
              Sensor take-off sandwich plates (fits under filter):
              Merlin Racing TGASP100
              Burton LMA110/M
              • csjcarolyn
                • 157
                Re: Oil Gauge
                Thanks guys, will be calling Burtons or Merlin on Monday!
