Where can I get rubber channel?
  • keith_h
    • 549
    Every time I take my seat belt off it flips back and takes a chip out of the bodywork just behind the door. Does anyone know where I can buy a 2ft length of square rubber channel (35mm along the internal base and say about 20mm walls). Has anyone come up with an alternative solution - apart from not letting the belt go?
  • austinm
    • 65
    Re: Where can I get rubber channel?
    East Kent trim supplies list square rubber extrusions but do not list sizes. Guess you would need to phone them.
    http://www.classiccartrim.com/phdi/p1.nsf/supppages/eastkent?opendocument&part=15
    • austinm
      • 65
      Don't now what happened there.
      That link doesn't work.
      Try East Kent Trim supplies on google.
      • copperleaves11
        • 326
        You could try Seals Direct, I would be surprised if they don't stock something suitable.Regards
        • keith_h
          • 549
          Thanks David - I tried them and they don't carry anything that wide
          • mike.mikewood
            • 14
            Keith
            Try the following:
            1. Edgware Motor Accessories (don't be out off by the name - they specialise in such stuff): www.rubbertrim.co.uk
            2. Woolies for trim: http://www.woolies-trim.co.uk/
            or
            3. Merlin Motorsport: http://www.merlinmotorsport.co.uk/TRIM/c516/index.html?osCsid=4254df0bb2359079903fb004effe9757
            • keith_h
              • 549
              Thanks Mike. I'm afraid I drew a blank on those as well. I've decided to open another thread asking a slightly different question.
