wheel nuts
  • bx16v
    • 7
    wheel nuts
    hi ,
    does anyone know of where i can obtain a new set of wheel nuts for my marina based marlin roadster ?
    thanks jue
    Re: wheel nuts
    Your nuts, as standard Marina should be 3/8"Unf, the same as used by many Triumph cars. They must suit the type of wheels you have.
    Ebay will help or Rimmer Brothers if you can afford them.
      Re: wheel nuts
      Or they could have been changed to 7/16"Unf. SAme sources apply.
      • austinm
        • 65
        Re: wheel nuts
        As Steve says 3/8 Unf.
        I got a full set of chrome domed nuts from a local classic mini specialist, ok if your wheels are 60 deg. taper like mine .
        Same nuts are on Ebay item no.280697612306
        Regards Austin
        • bx16v
          • 7
          Re: wheel nuts
          thanks peeps for your replys
