Steering rack
  • charles44
    • May 2014
    • 60
    Re: Steering rack
    Tell me more!
      • 929
      Re: Steering rack
      I thought they'd all be gone by now
        Re: Steering rack
        PM's sent.
        • newtrialer
          • Dec 2019
          • 18
          Re: Steering rack
          Steve.
          following through links looking for steering solutions as per the start of this thread. Is that quick marina rack still an available option ?
          thanks
          john
            Re: Steering rack
            I have no idea where the idea of a quick rack for a Marina based car came from, none at all. If you have located one, please share the info.
            The source I had for a while, was for a custom rack, I get no replies from them now, it was 5 years or more ago, so they probably don’t exist. I never actually saw one in the metal.
            The normal Marlin solution was to shorten the steering lever that is bolted into the upright.
            They are a devil to remove and after cutting a section out need careful machining before welding back together in the correct orientation.
            Fine for a trials car, but if spotted by an experienced MOT tester it is an immediate fail for road use.
            • newtrialer
              • Dec 2019
              • 18
              #21
              Re: Steering rack
              Ok, thanks.
              I have been told that Steve holder of fortune engineering as was in cheltenham had some ready made shortened arms, is that something you are aware of ? Does anyone have contact details for Steve Holder ?
                Re: Steering rack
                Steve Holder retired 10(?) years ago. Any remaining stock went to his then customer base.
                That avenue is closed.
                • MarkG
                  • May 2018
                  • 21
                  #23
                  Re: Steering rack
                  I was lucky enough to get the last pair a couple of years ago
                  • AndrewKB
                    • 124
                    #24
                    Re: Steering rack
                    Just to be clear. The Steve Holder mod did not make it a 'quick' rack, i.e. fewer turns lock to lock. What it did (does for those of us who have a pair of the SH steering arms fitted) is decrease the turning circle significantly. My Marlin will turn in a ridiculously small space, albeit with a bit more effort to get the steering wheel onto full lock, particularly if the front tyres are a little soft to reduce understeer (as sometimes needed on trials).
                      Re: Steering rack
                      Could not have said it better myself.
                      What you do lose is any stop to the steering angle, until the tyres make contact with the suspension components or bodywork, it’s not a quick rack per se, and there never was to my knowledge for a Marina.
                        • 929
                        #26
                        Re: Steering rack
                        I do remember seeing them mentioned. I think that someone manufactured a short run of them so they were snapped up pretty quickly.
                          Re: Steering rack
                          That would have been Steve Holder who retired about 10 years ago. His name crops up quite a lot amongst the trials community.
                            • 709
                            #28
                            Re: Steering rack
                            Coventry Automotive manufactured a run of rack conversion kits a few years back, on the back of their work on a rally-spec Marina project. There is mention of them on the Marina Owners club forum...priced at £325 back in 2016.
                              Re: Steering rack
                              Indeed, that was my source, there were no Marlin takers back then so I doubt that many if any will be found today in general circulation.
                              i was tempted, but not being a trailer, I didn’t invest. An opportunity lost perhaps.
                              • newtrialer
                                • Dec 2019
                                • 18
                                #30
                                Re: Steering rack
                                Fascinating trail of knowledge. Does anyone have the dimensions of the shortened steering arm ? I have a plan but the geometry is beyond me.
                                tHanks
                                j
