Wiring
  • philws
    • 23
    Wiring
    When I bought my Berlinetta there was a brand new wiring harness in the boot from Yorkshire Kit Cars, the wires look to be quite light duty, has anyone had any experience of this harness and are there any problems with it?
    Should I be using relays with the harness?
    Phil
    Re: Wiring
    Hi Phil,
    If your car is Sierra or Cortina based, and it used the original donor harness, then the relays for headlamps etc will hopefully already be on the car.
    The wiring you describe culd well be the modern "thinwall" cable which has a modern insulation on the correct sized core. I have recently rewired the fron part of my car with this cable and no problems yet!
      Re: Wiring
      Sorry for the sticky keys on my keyboardddddd*.
