Hi all, Now i have sorted my sidesceens i'm looking for a rear wind deflector. Any info' would be welcome. Cheers
rear wind deflector
Re: rear wind deflector
Hello Jim
I built a test one using 15mm copper tubing as per the diagram. I used compression fittings so that I could experiment with height and then soldered it up with Yorkshire fittings.During testing I simply made the legs long enough so that I could wedge it behind the seats. The netting is simply taped on with gaffa tape.
I have to say, I wasn't very impressed with the result but Bob Cawte has designed and built one from scratch as well and he used 2 thicknesses of mosquito netting.
When it is all done, you cover it with slit convoluted plastic harness tubing
I think Tim Hawkesworth has found a BMW Mini one works well but I suspect it was megabucks compared with the above.
Best of luck
Hi Jim
The one I recently built is using a MGF perspex one off ebay for £55 Plus a few more quid for fixtures and fittings.
Personally well pleased with it!!
A few pics in miscellaneous cat if you havent seen it.
If interested and want more info let me know youe email?
Bryan
Jim
Some pics re aboveAttached Files
Hi Keith
Good point!
I have checked my ebay purchase and it just says high impact MGF/TF wind deflector!
It seems there are none for sale at the mo anyway!!
bryan
