I think I've nearly got the problem solved, I can send the instructions but I still haven't cracked sending the map - maybe I will simply screen grab it
How do you send a Google Maps route to someone
Thats an interesting one Keith, I guess its possible but if the recipent has a computer, cant they generate the route map themselves?
If you find and answer, do post it, you have prompted my curiosity.MOC member since 05/97
If you're sending it electronically, generate the directions and then look for the little chain up at the top left hand side, next to the printer icon. That should give you a link to the map.
That should then give you something like
That works for me, thanks for that.MOC member since 05/97
