V8 Exhaust manifolds for the Marlin
  • HunterV8Spain
    • 35
    Does anyone know where these are available?
  • CosworthCabrioLee
    • 924
    Re: V8 Exhaust manifolds for the Marlin
    Hi you will need to get itmade to fit the car as will need to be bent around the column etc . Not sure about Spain but peoLe like pd tough of Nottingham or power speed auto of Kent will do these but at a cost. You may struggle to get change out of £1000 for both headers and if you go the whole hog with the full system budget £2000
    I will try and find some pictures of some headers on a v8
    • HunterV8Spain
      • 35
      Hi, thanks Lee, I do already have a set on my car which have had a minor repair. Thought about replacing them with new ones but a price of at least a Grand has changed my mind somehow..........
      • CosworthCabrioLee
        • 924
        Some pictures of a V8 i used to own theexhaust was supplied by Marlin but in mild steel.
        What have you got on your car................
        • HunterV8Spain
          • 35
          Mine look to be the same as those, in mild steel also - the rest of the system is stainless.
            • 1644
            These manifolds are on the 3.9i V8 on my Hunter. They are a 4 into 2 into 1 set up on both sides - unlike Lee's photo which appear to be 4 into 1. My 2 into 1 join is out of the photo under the floor area. Mine are stainless but the non-preferred brittle spec, hence the fracture I experienced some while ago, now repaired. Local firm Phoenix gave a ball park quote of around £1000 for new ones too! They also suggested having them ceramic coated for heat insulation rather than using heat wrap. Peter.
