Speedo cable
  • Gareth
    • 502
    Speedo cable
    Hiya, Anybody know what car uses the same speedo cable as my Marina based Roadster? The outer cable is 50 inches long, and the gear box end
    Is held in place with a y shaped bracked, secured by one bolt, and the speedo is a Smiths speedo and the cable screws on, not push and clipped on type.
    I've sern earlier postings and a part no. MSD 502, but that appears to be the push on type.
    Cheers, Gareth.
    • 590
    Re: Speedo cable
    Gareth,
    Contact speedy cables. They will make exactly what you want. The length you need, the outer cable finishers you need and the internal cable end profiles will be all they need to make it.
    Jon
      Re: Speedo cable
      If you have doubts, send them your old cable as a pattern.
      I might still have my old one from when I swapped gearboxes somewhere in my garage.
      • Gareth
        • 502
        Re: Speedo cable
        Many thanks Jon, I've sent them a picture with the e mail. And Steve, I'll let you know if I don't have any joy, cheers Gareth.
        • CosworthCabrioLee
          • 924
          Re: Speedo cable
          Gareth give me a call I have one I think if it will help you regards lee
