After seeing small drips of water under the cabrio on the garage floor, upon further inspection the air intake pipe for the induction kit has been rubing on the radiator core and put a tiny hole in it. So the radiator is out and booked into get repaired. But the question is what type of anti freeze to use ??? The v6 cosworth has cast block and 2 alloy heads as well as other alloy components. Pink or blue what is the difference and best corrosion inhabitors.
Thanks in advance lee
