SU starvation?
  • stephenlilley
    • 102
    SU starvation?
    I have a roadster with a series b Marina 1800 with (Apparently) dolomite SUs . These have just been totally refurbed but I now have a problem. When I go round a left hand bend, It almost cuts out. I have fitted an electronic fuel pump to see if that was the cause. It still happens. It feels like fuel starvation but on a straight run its fine and pulls well. Any ideas?
    Great to meet up at the Newark show.
    Steve Lilley
    Re: SU starvation?
    this sounds like the old water in fuel problem that used to be a pig to cure in the olden days. I had it on an old What would happen would be that a blob of water would get sucked up from the tank and settle on the bottom of the fuel bowl and then get into the little pipe. On a left-hand bend th water gets into the jet and causes it to cut out for a second or two. Seriously! I bet its some watery crud in there!
    • stephenlilley
      • 102
      Re: SU starvation?
      Thanks Cameron, That sounds very likely as the car was outside for a few days in the pouring rain with an ill fitting petrol cap which I have now replaced.
      I'll clean it all out and see how it goes
      Thanks again
      Steve
        Re: SU starvation?
        Hi Steve, We spoke at Newark yesterday to prove Camerons theory try pumping a cup full of fuel into a clean jam jar and let it stand, you will see the water as a bead at the bottom.
        Ref your cars history, not a lot but have PM you what there is.
