Vacuum unit for a 48D4 dizzy
  • almyland
    • 118
    Hi
    I've been given a used 48d4 distributor that hasn't been used for several years and I suspect that the vacuum unit my not be up to par! Can anyone suggest where I might get a replacement vacuum - new or used but pretty sure is in good working order. I've been struggling with a new A Series Spares electronic dizzy but, despite returning it to them three times now, it still leaks oil into the dizzy body. The seal keeps failing. I've just about given up on them to resolve the problem and I'm reverting to a standard dizzy.
    Thanks
    Alan
    Re: Vacuum unit for a 48D4 dizzy
    I did a 25D dizzy at http://www.fastmarinamagazine.com/in...ic.php&p=34596
    The same method might work for you.
      Try 'Distributor Doctor' on internet
      • mark westbrookwhite
        • 146
        If its any help both my son for his classic Mini and I for my MGB engined roadster bought electronic distributors from
        www.simonbbc.com Good value good service and they work brilliantly my son has been using his for two years without a peep out of it on a car he was always messing around with the points on before.
