Marina rear bushes
    Marina rear bushes
    Message originally posted by: jim pailing
    Have a 'box of bits' which should be an '84ish Roadster. But what are the rear of the rear springs hung from, I have 2 20mm holes but no bushes ?
    Also no docs so would be interested in knowing identity, red and has large bolt as part of handbrake lever mechanism.
    Jim
    Re: Marina rear bushes
    Jim - you need the original Marina shackle plates and bushes. Polyurethane bushes are better and can be obtained from Superflex. The bolt in the handbrake is standard Marlin. I've emailed a copy of the Haynes diagram for the rear spring mounts and the Marlin build instructions for the handbrake and suspension. Enjoy the jigsaw...
