There are no ARB brackets on my hybrid chassis. My prime intended purpose for the Marlin is trials, so since I want to keep both rear wheels firmly on the ground as far as possible I feel a lack of ARB is acceptable because the front suspension will articulate more easily with no ARB.
But, what about normal road use, Will it likely wallow, like a sow pig's belly, every time it sees a corner?
If I am to have an ARB, then the time is fast approaching when I need to fit the brackets.
So, ARB or not, what say you?
