Tie Bars
    Tie Bars
    Message originally posted by: Lee Hunter
    Please see pictures of the new tie bars that we have created for my roadster they locate the front suspension far better than using the blue poly bushes. The handling is much more precise and under braking too. They have a main solid part which is machined out and bolted to the chassis and 1/2" Rod ends screwed onto the original tie bars.
    Lee Hunter
    Re: Tie Bars
    Hi Lee
    Is this something that a company is making up for you, or just passing some information on? I think it is Hugh who has done a similar thing as well..
      Re: Tie Bars
      Hi Stefan
      No, this is completely our idea all the parts have been machined in our workshop except for the rod ends they were bought in. Like i said it makes the car handle much better as the wheels do not move backwords over bumps or braking..
      Lee
      Ps You coming to the lakes..?
        Re: Tie Bars
        Ah, rightio I don't actually see much trouble under braking/steering as is mind
        I plan to come across yes Just need to check dates (I presume they'll be in the next PitStop edition?).
          Re: Tie Bars
          Ah, I now know what you mean - actually felt it moving under braking today.
          I shall have to have a deeks at the Lakes trip - when are you planning it? (I'm off to Scotland for a break next week, MOT the week after, GoodWood Festival Of Speed 23-25th and then the cars in for some bodywork until early July).
            • 709
            Re: Tie Bars
            Are you taking orders Lee...
            • me
              • 23
              Re: Tie Bars
              Hmm, maybe I was to subtle
                Re: Tie Bars
                Hi Jez
                I may make some more of the tie bars in the future i will have wait and see, but if the interest was there i would certainly look at doing them to order.
                • paulhyder
                  • 141
                  Re: Tie Bars
                  Hi Lee are you using rose joints at both ends of the rods,
                  I would be interested in buying apair if you are taking orders Jeff Ganderton
                    Re: Tie Bars
                    Message originally posted by: Matthew Sykes
                    A word of warning about Rose joints(spherical bearings) on road vehicles, they are very noisy and wear loose very quickly (I use them on the shockers on my competion LR). The other thing top bear in mind when using them on the tie bars is they transmit much more of a shock loading to the mounts on the chassis as there is no cushioning like rubber/poly bushing and can cause failure of the mount or the chassis around the mount.
                    Sorry to be pessimistic but they will probably be fine for the track but become and expesive pain on the road unless you replace them every 4>5 months.
                    Matthew
                      Re: Tie Bars
                      A Teal (Bugatti replica) I saw at Stoneleigh, using marina suspension, had the tie-bar located with a track rod end. The track rod ball joint was threaded onto the chassis end of the tie bar with the tapered pin located in a bracket on the chassis. Obviously this would require some welding and modification to the chassis to adapt to a Marlin, but track rod ends do have the advantage of being weather proof and cheap.
                        Re: Tie Bars
                        Hi Matthew
                        I am only using a rose joint on 1 end of the tie bar the end towards the chassis. I also have put a small 3/4mm thick Poly bush, to cut down any noise from the tie bar and give a small amount of cusioning. I have used this type of rose joint before on the rear of the car both on the anti tramp bars and on the panard rod with no problems and the car i beleive is on of the best handling roadsters around.
                        Lee
                        • paulhyder
                          • 141
                          Re: Tie Bars
                          Lee , I'll agree with you on the handling and would be interested in who manufactures the rose joints, admittedly mine on the LR are subject to a lot more abrasive mixtures than you would expect on the road. If they do just the spherical bearing s in the same specs I'd love to try some on my shockers I(if they do the right size)and see how well they last.
                          Matthew
