Rain forecast today, so some indoor tasks to do, like the head...
When I found the Marlin in the wood and was told it had been there since 1988, it didn't quite sink in how badly the corrosion had affected it. At Easter I had a naive idea of getting the engine running! Ha, no chance, it was totally seized, a big socket on the crankshaft front bolt was met with the most solid resistance, either tightening the bolt or releasing it, but no turn engine. I had even taken a battery and some fuel!
The bores were reasonably free of corrosion, the pistons were bad around the rings and that was why the engine wouldn't turn. This is perhaps the most spectacular corrosion I have come across inside the engine. All the ports were similar, I had to hammer this inlet valve out. I kept one chamber to photograph before I cleaned it.
A bit of valve grinding to do today I think.
Marlin Port Corrosion c:u.jpg
and maybe a tickle with a wire brush?
