Ford Pinto Camshaft - Free
    • 1640
    Used camshaft from my Ford Sierra 2.0GL (Pinto). Had done approx 70k miles and was replaced unnecessarily. Cam lobes and bearings appear unworn. Just shiny next to blackadised original surface. Cam followers are identified 1 – 8 so they can go back matched to camshaft lobes.
    Free to a good home! If any use to anyone please let me know or drop me a PM, otherwise it will go in the scrap bin! Can bring it to Westpoint Kit Car show next weekend. Peter.
  • lizbillings
    • 828
    Re: Ford Pinto Camshaft - Free
    Hi Peter.
    Isn't Westpoint the last weekend of Oct?
    Regards Liz
      • 1640
      Oops! Yes Liz you are correct, Westpoint is the weekend after! I plan to be there on Sunday 28th Oct.
      Phew! I have just gained an extra week this month Peter.
      • fredsajs
        • 131
        Hi Pete.
        Iam looking for a standard cam for 2.0ltre Cotina.
        If you think it will be ok then I`ll have it please.
        Not attending any shows so will need it posting to Sussex !.
        Berlinetta Fred.
          • 1640
          Originally posted by fredsajs View Post
          Hi Pete.
          Berlinetta Fred.
          Hi Berlinetta Fred.
          The only info that I have is on the box of the aftermarket camshaft that I fitted to my Sierra, as I put this my Ford one in it to keep the followers in the correct order.
          On that box it says FFL2000 OHC Capri, Granada, Scorpio, Sierra models Sept 1983 onwards.
          Unless the age of your 2.0 litre Cortina engine fits in the above age bracket I suspect that it may not be suitable. Does anyone else on the forum (Danny perhaps) have any more specific info?
          BTW it is quite a heavy lump so I guess the postage would be similarly heavy. Do you know any other MOC members in your area that may be coming to Westpoint who could bring it back for you? There are some (non MOC) people on the Madabout forum coming if you know any of them?
          Hope this all helps.
          Peter.
          • fredsajs
            • 131
            Peter
            Cortina is a 1985 reg on 1989 (I believe same as Capri). You state 1983 ?. do you mean 1993/ 0r 83 ?.
            I do not kno of any club members near me on East Sussex coast, so if you think may fit let me know on postage costs and I`ll re`emburse.
            Berlinetta fred
              • 1640
              Peter
              Berlinetta fred
              Definitely 1983 on the label. My Sierra was a 1987 model (E Reg).
              It would be good to be sure that it will fit first. Apart from valve timing angles the camshaft bearings will have to be exactly right match. I will check if my old Haynes manual gives any such data.
              Meantime maybe you can make a separate post query in the Berli forum section as people may not look at the classifieds very often? Peter.
              • fredsajs
                • 131
                o/k will look.
                Berlinetta fred.
                  • 1640
                  o/k will look.
                  Berlinetta fred.
                  Have you found any data yet?
                  I have extracted the following info from my old Haynes manual:
                  FORD 2.0L PINTO - VALVE DATA FROM HAYNES MANUAL
                  Bearing journal diameter Front 41.987 to 42.013mm
                  Centre 44.607 to 44.633mm
                  Rear 44.987 to 45.013mm
                  Valve Timing All except engine code NAE Engine code NAE
                  Inlet opens 24 deg BTDC 18 deg BTDC
                  Inlet closes 64 deg ABDC 58 deg ABDC
                  Exhaust opens 70 deg BBDC 70 deg BBDC
                  Exhaust closes 18 deg ATDC 6 deg ATDC
                  Code NAE seems to refer to the P100 vehicle application. See Wikipedia link:
                  Hope this helps. Peter.
                  • fredsajs
                    • 131
                    Hi Peter.
                    Posted reply , but not come up !.
                    Basicly we are in tune with spec data.
                    Can you confirm why it was replaced apart from 70,000 mies.
                    Also if you are in acceptance, Ebay postage on simular units are roughly £10.
                    So how do we proceed ?.
                    Fred
                      • 1640
                      Hi Fred.
                      I have sent you a PM earlier this evening.
                      My reply to your last post hasn't appeared on this thread either. I will PM Cameron.
                      Regards.
                      Peter.
                      • fredsajs
                        • 131
                        Hi Peter
                        Awaite to here from you.
                        Fred
                          • 1640
                          Hi Peter
                          Fred
                          Hi Fred. Have just sent you a PM with postal info. Peter.
                          • fredsajs
                            • 131
                            Hi Peter.
                            Thanks for update.
                            Have given all my details on reply to yor messages, both received together to-day.
                            Hope not too cold for you Regards
                            Fred.
                              • 1640
                              Hi Peter.
                              Thanks for update.
                              Fred.
                              Hi Fred.
                              Camshaft posted today. Have sent you a PM. Regards. Peter.
