More questions.
  • Jools
    • Aug 2012
    • 35
    More questions.
    There are always more questions than answers, or so it seems.
    Has anyone got any ideas how to remove the facia top panel (padded & trimmed) from the dash without excessive dismantling? Similarly I am trying to source a set of blue seatbelts (to match the new trim colour). The existing are securion 500/30. Will any other fit?
    Cheers Jools.
  • bryannewell
    • 331
    Re: More questions.
    Hi Jools
    Mine is only held on with 2 self tappers at each end (only visible with the doors open!)
    I dont imagine they are all done this way tho!!
    Good luck
    Bryan
    • CosworthCabrioLee
      • 924
      Re: More questions.
      Hi Jools there should be fixings either side of the top panel, then it should lift off.
      See picture
      • Jools
        • Aug 2012
        • 35
        Re: More questions.
        See picture
        Thanks for that. I will have a closer look.
        • Jools
          • Aug 2012
          • 35
          Re: More questions.
          Ah-AH guess what, it was just a push fit (fairly tight mind) with NO screws. I have been looking for fixing screws everywhere. DOH!!!!!!!!
          Thanks for your replies folks.
          Still looking for blue seat belts.
          Cheers. Jools.
          • CosworthCabrioLee
            • 924
            Re: More questions.
            Hi jools it way be worth looking at cars like fiat and French cars as they used to do some funny coloured interiors. i put red ones in the black roadster out of a mg metro
            • CosworthCabrioLee
              • 924
              Re: More questions.
              170948571099 eBay out of a Astra
                Re: More questions.
                some saxos had blue belts iirc
                • Jools
                  • Aug 2012
                  • 35
                  Re: More questions.
                  Thanks, do you know if they mount the same?
                  • CosworthCabrioLee
                    • 924
                    Re: More questions.
                    Yes they will fit you will need to go to the scrappy for the plug in bits....
