Slow progress with the Marlin exhaust
  • Harry
    • Dec 2012
    • 239
    My parts arrived from ebay and Demon Tweeks, one new silencer, rubbers and clamps, I was ready to do a bit but the clamps turned out to be 52mm and not the 54 I requested, still, off I went and made a start, I removed the old box and connecting pipe along with the broken bracket, measured up the connecting pipe ready for a new fabrication to be made, I got my best hacksaw out and removed 40mm from the end of the down pipe ( Replacement box is longer and has a much larger diameter) as I lay down next to the car measuring up, I was distracted by a nasty draft under the garage door, so I then fitted a strip of carpet to the door bottom - sorted. Maybe this weekend I will get round to fitting the new silencer on new hangers, if it's not too cold ?
