Berlinetta build and restoration
    Re: Berlinetta build and restoration
    Looks very good Scott.
    You say this mimics your old V8 twin tail outlet - did you ever get exhaust fumes rolling back into the cabin with it?
    I made a very similar twin tail arrangement on my Cabrio as it looks good like this, but had to change the delivery at the rear as I had quite bad exhaust fumes rolling back into the car.......maybe the Berli's different shape means the airflow behaves differently?
    • scott h
      • Mar 2013
      • 670
      #122
      Hi Mike, I remember reading how you had to change your exhaust once your car was road tested. It was of particular interest because of the similarity to my original exhaust. I never had any such problems with my Berli but probably the big difference is that I always had the hardtop fitted. I plan still to be hardtop only, although perhaps in the distant future a soft top could be a project.
      Scott.
        • 1237
        #123
        Hi Mike, I think the exhaust fumes coming back was only ever with the Cabrio. I have never had the problem with a Berly, and I have never heard of any one else. Strange!
        Danny.
        • scott h
          • Mar 2013
          • 670
          #124
          I fitted the fuel sender to the tank today. In my Berli's first life the sender leaked, and there were two reasons that made it difficult to cure. One was that the sender was mounted on the side of the tank and so was submerged in fuel a lot of the time. The second reason was that it was mounted using self tapping screws, as supplied with the sender, which did not hold it tight enough. So with the new tank I had the hole for the sender put on top of the tank, and I thought that I would mount it using stainless set screws which would bolt to captive nuts on a ring inside the tank. I tested the sender by wiring it to the gauge using a battery and it worked fine, both the gauge and the sender are still available to buy new which is piece of mind for the future.
          The sender with the previously bent float arm now straight showing how it will sit in the tank.
          Stainless steel ring with captive nuts.
          Finally mounted.
          I did plan to trial fit it then remove it and paint it, but it was like a puzzle getting the ring, the gasket and the sender all to line up. So it's staying on and I will paint it where it is!
          • scott h
            • Mar 2013
            • 670
            #125
            I made a mount for the fuel pump from off cuts of stainless steel today. I decided on a Facet solid state pump which will supply a swirl pot in the engine bay. The swirl pot has an overflow return back to the tank so this pump will constantly circulate fuel, and I had to take this into account when deciding what size of the three available pumps to buy. I was thinking it would be silly and risky having too much fuel constantly circulating so I was going to get the standard size pump as it is rated at twelve gallons per hour which seems plenty to me. But it is only recommended for up to 1600cc engines so I went for the fast road one rated at eighteen gallons per hour, which is recommended for 2000cc engines up to 150hp.
            The large inlet union is a filter.
            Once it was mounted it looked a bit exposed to flying debris so I made a guard. I left it open at the top and bottom as I was not sure if the pump may heat up if it was in a closed box.
            • scott h
              • Mar 2013
              • 670
              #126
              Vauxhall c20xe engine to Ford type 9 gearbox. I sorted out the clutch and I thought a wee post about the parts that I used may be helpful to others. The first thing you need is a bellhousing and there are four types. When the engine is fitted in a front wheel drive Vauxhall it is tilted at seven degrees to give more room for the inlet manifold. Rear wheel drive bellhousings are available to keep the engine at this angle or have it vertical, so these are the two main types. The Ford type 9 gearbox comes with a standard length input shaft, or as fitted to Capris a longer input, which requires a different bellhousing. So between the vertical, tilted, standard and long input you have four variants.
              The next thing you need is a clutch plate, this needs to be the diameter of the Vauxhall plate but with splines to suit the Ford gearbox, use the standard Vauxhall clutch cover. The C20XE engine comes with a choice of two flywheels, the earlier flat one and the later so called pot flywheel, which as the name suggests has a recess for the clutch plate. The only time you need to worry about which one you have is if you are buying a new clutch cover, apart from that the set up is the same. The standard Ford spigot bush fits the Vauxhall crankshaft. The release arm recommended is the Ford Escort Mk11 RS2000 as it is slimmer. Use the standard Ford release bearing.
              There are three main companies that deal with this conversion.
              Yukspeed. Run by a guy called Yuk who is a character that would make a good candidate for the Top Gear vacancy, during a ten minute phone call he told me several tales one of which was getting drunk with Russel Brooks! His prices are the most competitive. The website just gives contact details.
              SBD motorsport. A good website with instructional diagrams and information.
              QED. Have the parts for this conversion but perhaps more suited to serious motorsport.
              Special clutch plate and new Vauxhall cover.
              RS2000 release arm and bearing.
              Bellhousing, this one is the tilted version.
              A rough price guide:
              Bellhousing and bolts £200.
              Clutch plate, spigot bearing and release bearing £90
              RS2000 release arm £40.
              • scott h
                • Mar 2013
                • 670
                #127
                A milestone has been reached. So far in the rebuild most of the parts have been trial fitted then removed, I must have sat the engine and gearbox in at least ten times for example, but now it is time for the final assemble, touch wood!
                Here the engine and gearbox, lower bulkhead, steering, pedal box and brake servo are in position to stay.
                • scott h
                  • Mar 2013
                  • 670
                  #128
                  Pedals mounted with the clutch and brake pedal working although no brakes on the car yet.
                  On the left is the clutch pedal with adjustable stop and return spring. On the right is the brake pedal with the brake light switch and return spring.
                  Clutch cable attached to pedal.
                  Clutch cable adjustable at the bellhousing.
                  • scott h
                    • Mar 2013
                    • 670
                    #129
                    I managed to grab some time in the garage in between the busy harvest work on the farm. I mounted and plumbed in the fuel swirl pot, injection pump and filters. I did fancy stainless braided hoses but after some research I went for standard black fuel hose. It seems that with modern corrosive fuel any leak is more likely to come from the inside out and the steel over braid makes it difficult to spot.
                    I also started to sort out the plumbing of the cooling system.
                    I got the biggest diameter of fan that would fit in the cowl, with an inline adapter for the fan switch. I thought about an adjustable switch but decided to go for the standard switch but probably with a manual switch on the dash as well.
                    How often have you tried to buy a part for a kit car and tried to explain to the parts guy that you don't know the reg No. or the exact model? It often makes no difference if you know the exact part that you need, without the reg or year these days the answer is computer says no! So it was refreshing when I came to buy a shorter alternator drive belt, due to no longer driving the power steering pump, to find a seller on ebay that listed belts by spec instead of which car that they fit. So it was a case of measure the length, number of ribs and width, and hey presto the web site told me that the belt that I required is originally intended for a Toyota Yaris, simples!
                    • scott h
                      • Mar 2013
                      • 670
                      #130
                      Cooling fan mounted.
                      Using folded stainless brackets.
                      • scott h
                        • Mar 2013
                        • 670
                        #131
                        Cooling system pipework.
                        The bottom radiator hose with in line fan switch. In the Vauxhall donor car this switch is fitted to the bottom corner of the radiator, so this position is close to the original.
                        A mate welded the ally pipe at the top of the pic, with outlets for the heater and header tank.
                        This is the original plastic pipe with the outlets in all the wrong places.
                        Pipes to the heater through a valve to control the temperature.
                        The other heater hose connects to the rear of the cylinder head.
                        Heater hoses fitted through a removable panel in the heater box.
                        Heater box in place.
                        I decided to use molded bends rather than straight pipe bent to shape which would probably kink when it gets hot. However the down side of this is lots of joins with lots of hose clips which may look untidy.
                        All the joins are made with ribbed inserts.
                        • scott h
                          • Mar 2013
                          • 670
                          #132
                          I keep telling myself don't panic it's only a couple of wires! Time to sort out the engine loom.
                            • 2797
                            #133
                            Indeed - what's your problem ? LoL
                            • scott h
                              • Mar 2013
                              • 670
                              #134
                              I had a propshaft made by Northwest Propshafts. http://www.northwestpropshafts.com/. I chose this company mainly because they had a stand at Stoneleigh in 2014 and were very enthusiastic when I spoke to them. I made this known to them when I called them to discuss having a prop made, the hope is that it will prove that having a stand at the show results in sales and so encourage them to return. I think that as kit car owners we should take every opportunity to help the few remaining shows to survive.
                              To suit the Ford type 9 gearbox and Sierra diff they offered a prop with standard U/J's or heavy duty ones. The standard one is suitable for up to 175hp and the heavy duty one will handle 300hp. The prices are £115 and £145 respectively, this includes next day delivery but not the dreaded VAT. With my engine being rated at 150hp, but with tuning another 50hp is easily found, so I went for the heavy duty version.
                              The U/J's are replaceable being held by circlips as opposed to staked. They also have grease nipples.
                              With independent rear suspension where the diff is fixed to the chassis, it is important that the propshaft runs at a slight angle to provide some movement in the joints, to prevent premature wear. I had this in mind when I positioned the engine and gearbox, it sits 20mm to the nearside which provides clearance between the brake servo and the intake manifold, and helps with the aforementioned prop angle. It was a relief to find that the plan had worked out when I tried the prop on for the first time tonight.
                                Off setting the the u/js is a good idea, but make sure the two flanges are still parallel to avoid causing vibration.
