Progress to date: Robert's Roadster
  • Robert in Cumbria
    • Mar 2012
    • 603
    #61
    Re: Progress to date
    I don't know if this will work...
    This is my spreadsheet list of tasks for the Marlin. it appears here so it may post?
    Chassis Tasks
    Completed
    Comments
    Create Rear Gearbox mountings
    YES
    Fit gearbox mountings
    YES
    Make inriggers for gearbox mounts
    YES
    Fit inriggers
    YES
    Make engine mountings
    YES
    Weld in the engine mountings
    YES
    Trial fit engine and gearbox
    YES
    Adapt rear chassis for raising suspension
    POST MOT
    Measure up for propshaft
    YES
    Shorten propshaft
    NO
    Original propshaft OK
    Make seat mountings
    YES
    Weld in seat mountings
    YES
    Make roll bar and mountings
    POST MOT
    Install roll bar and mountings
    POST MOT
    Cut holes in 4x2 screen X Member
    YES
    Make strut brace
    POST MOT
    Make rad support
    YES
    Make battery box
    NO
    Have material
    Weld hinges to ‘A’ posts
    NO
    Make brackets for temp fuel tank
    NO
    Have material
    Suspension Tasks
    Completed
    Comments
    Order parts for front suspension
    YES
    Fit rubber bushes
    YES
    Assemble front suspension
    YES
    Make dowels for Van back spring mounts
    POST MOT
    Clean and paint Van back springs
    POST MOT
    Assemble Van back springs
    POST MOT
    Final fit back axle using Car springs
    NO
    Steering Tasks
    Completed
    Comments
    Slot mounting holes in chassis brackets
    YES
    Clean and lube Rack
    YES
    Fit gaiters
    YES
    Fit Rack
    YES
    Fit track rods to steering arms
    YES
    Final Fit steering column
    NO
    Track up
    NO
    Fit steering lock
    NO
    Engine Tasks
    Completed
    Comments
    Strip and clean engine
    YES
    Get crank polished
    YES
    Strip heads
    YES
    Clean up heads
    YES
    Port old head
    POST MOT
    Clean valves up
    YES
    Grind valves in
    YES
    Re assemble head with new stem seals
    YES
    Get block back from LE
    YES
    Clean and paint
    YES
    Assemble short motor
    YES
    Fit head assy
    YES
    Lighten flywheel
    NO
    Some scope but deferred
    Fit flywheel and clutch
    YES
    Fit water pump and dizzy
    YES
    Fit engine to gearbox, mount in chassis
    YES
    Fit manifold and carb
    YES
    Fit starter and alternator
    YES
    Fill with oil
    YES
    Test start
    YES
    No water, needs timing.
    Clean and test radiator
    YES
    Fit radiator
    YES
    Fit coolant hozes
    YES
    Pressure test cooling system to +1 Bar
    YES
    Test run, check for leaks
    NO
    Fit oil warning lamp switch
    NO
    Clutch Tasks
    Completed
    Comments
    Clean pressure plate
    YES
    Clean centre plate
    YES
    Clean slave cylinder
    YES
    Clean master cylinder
    YES
    Get slave cyl kit
    Pending
    May be OK
    Get master cyl kit
    YES
    Fit kits
    YES
    Clean and lube release bearing
    YES
    Assemble actuation lever
    YES
    Fit master cyl
    NO
    Fit slave cyl
    YES
    Connect and bleed
    NO
    Test
    NO
    • Robert in Cumbria
      • Mar 2012
      • 603
      #62
      OK, it seems to work, but limit's me to 20,000 characters. Not sure how it counts more than 20,000 characters here but there you are.
      Gearbox Tasks
      Completed
      Comments
      Clean o/d filter
      YES
      Fit new sump gasket
      NO
      Obtain and fit hex drain plug
      NO
      Clean clutch housing
      YES
      Paint clutch housing
      YES
      Replace front oil seal
      YES
      Fit new Clutch housing gasket
      YES
      Fit gearbox
      YES
      Fill with oil 20-50
      NO
      Test operation of o/d unit
      NO
      Transmission Tasks
      Completed
      Comments
      Replace propshaft front joint
      In Progress
      Clean and paint propshaft
      In Progress
      Drain oil from diff
      NO
      Fill with new oil GL4?
      NO
      Fit new axle casing breather
      NO
      Exhaust Tasks
      Completed
      Comments
      Make and fit Downpipe
      In Progress
      Auto Perormance Morecambe
      Make and fit System
      NO
      Fit and test mountings
      NO
      Wiring & Electrical Tasks
      Completed
      Comments
      Adapt and check wiring harness
      NO
      Fit rear lights inc rear fog
      NO
      Fit bracket for rear numberplate and lamp
      NO
      Wire back lights
      NO
      Adapt and Fit side lamps
      NO
      Repair and fit headlamps
      NO
      Fit front indicator lamps
      NO
      Wire Alternator
      NO
      Test Alternator
      NO
      Wire starter and solenoid
      NO
      Wire Radiator fan and switch
      NO
      Install Battery and main feed cables
      NO
      Mount and connect switch gear
      NO
      Fit horn and horn button
      NO
      Make bracket for front Number Plate
      NO
      Wire o/d and fit switch
      POST MOT
      Wire for speedo illumination
      NO
      Bodywork Tasks
      Completed
      Comments
      First Fit nose cone
      YES
      First Fit side panels
      YES
      Make extensions for side panels
      YES
      First Fit back tub
      YES
      First Fit back wings
      YES
      First Fit front wings
      YES
      Make and First fit hockey stick wing brace
      YES
      Need 4 Button M8 SS bolts
      Final fit Nose cone
      NO
      Final fit side panels
      NO
      Final fit back tub
      NO
      Final fit back wings
      NO
      Final fit hockey sticks
      NO
      Final fit Front wings
      NO
      Make step bracket under running board
      NO
      Adapt and fit screen valance
      NO
      Started
      Make and fit doors
      NO
      Make and fit dashboard
      NO
      Fit speedo
      NO
      Check speedo for accuracy
      NO
      Calibrate speedo
      NO
      Fit interior mirror
      NO
      Fit exterior mirror
      NO
      • Robert in Cumbria
        • Mar 2012
        • 603
        #63
        There, it's swallowed it and kept my formatting.
        Floor and Bulkhead tasks
        Completed
        Comments
        Modify bulkhead panel
        In Progress
        Patch Bulkhead to side panels
        NO
        Alter o/s seam in footwell to increase space
        NO
        Cut and fold floor panels
        In Progress
        Cut and fold Passenger footwell
        In Progress
        Cut and fold drivers footwell
        NO
        Drill and tap fixings for floor plates
        NO
        Cut and fold under seat panel
        YES
        Form panel for gearbox cover
        NO
        Final fit pedal box
        NO
        Brakes Tasks
        Completed
        Comments
        Clean and reassemble Master cylinder
        YES
        Fit Master cylinder
        NO
        Fit front flexy’s
        NO
        Make and fit solid brake pipes
        NO
        Connect up back brakes
        NO
        Bleed and test foot brakes
        NO
        Connect vac pipe to servo
        NO
        Install handbrake
        YES
        Connect handbrake
        NO
        Test handbrake
        NO
        This isn't going back to the start, just from when I had stopped pulling stuff to bits.
        • Robert in Cumbria
          • Mar 2012
          • 603
          #64
          A couple of photographs of the floor going in.
          [ATTACH]3464[/ATTACH]
          [ATTACH]3465[/ATTACH]
          I had the engine running last Sunday, it started at the first attempt after I got the oil pressure up. Running on all four and quite sweet, if noisy!
          Hoping to finish the floor tomorrow and start finishing the front bodywork, may be a bit optimistic with the shorter evenings now.
            oooh that's nice
              Hi Robert
              It may be the angle of your photo, but couldn't you have fitted your engine quite a bit further rearward, to help take the load to the back wheels for hill climbing?
              (It made me smile as I can barely get a cigarette paper between my rocker cover and the bulk head, and the servo has to be limited in diameter, whereas you have acres of space!)
              • Robert in Cumbria
                • Mar 2012
                • 603
                #67
                Hi Mike, I have room for a V8 in there! It grieves me when I see Land Rovers in breakers yards with good fuel injected V8 lumps, going for scrap. But then I think of the fuel they would guzzle.
                Moving the engine right back occurred to me when I first saw the car again, I could see the potential for moving the engine back best part of a foot, why stop at the bulkhead? In fact the bulkhead is about in line with the front of the gearbox, since the clutch housing is 200mm I could easily have gained eight inches without touching the bulkhead.
                However... The National Trials Association regs state that to be eligible for class 7 the No 1 spark plug must be no more than 410mm behind the centre line of the front axle. I don't believe moving a 1275cc engine back even 12 inches would even begin to make me competitive in class 8 (Which are mainly special rear engined, high powered cars), so I decided to stay legal to class 7 (hopefully). I have made the engine mounting brackets with space to move the engine back about 45mm but that would also entail altering the gearbox mounting, so not that easy. Adding the overdrive gearbox has increased weight significantly and I am hoping all the weight I have added in the 'A' post and bulkhead area isn't too much of a penalty. I think I have saved some weight in other parts so perhaps it has evened out? The test will be to weigh it when I have finished. Hoping for 650Kg unladen but it may be a bit more... I am hoping for a 40%-60%, front - rear ratio, laden, we will see. The seats are heavy, with their integral seat belt mountings, the seat brackets are heavier! but at least they are near the back...
                I am very un-decided about the windscreen frame, which weighs a ton. For the MOT I am not going to fit glass, meaning I don't need wipers or washers. That will give me an opportunity to assess whether running without a screen reduces buffeting. I am going to fit a rear roll over bar once the MOT is done and the car on the road, I could replace the original ultra heavy screen frame with a steel tube hoop which could arguably be more effective than the original solid frame and definitely much lighter and could still be glazed if I wish.
                • Robert in Cumbria
                  • Mar 2012
                  • 603
                  #68
                  Originally posted by cameronfurnival View Post
                  oooh that's nice
                  The aluminium checker plate does look good! I just hope I can make a nice job of installing it. There won't be any carpets, so any blemishes will be plain to see. I am really looking forward to making the gearbox cover, that WILL be a challenge.
                  • gary.price
                    • 113
                    #69
                    Shes really coming together then. Looking great That list is gonna take a day or 2 tho. Should work out really well.
                    • gary.price
                      • 113
                      #70
                      You dont want to be class 8. Wise move. I would keep a little quiet about what youve done tho. Cause they can be picky when everything is ok. You want that heavy windscreen frame. Its the roll bar! And you will be grateful of the windscreen when its minus 9 at 3 o'clock in the morning. Plus it will keep mud water and stones from hitting you in the head and face. If your worried about heavy seats just go a diet lol. The previous owner of mine had tractor weights behind the seats. Iv fitted mine to the wheel carrier to keep the weight back.
                        Steven -dont you mean three oclock in the afternoon - there isnt a three in the morning is there?
                        • Robert in Cumbria
                          • Mar 2012
                          • 603
                          #72
                          I find having two, three O'clock's in one day very puzzling.
                          Two more tasks ticked off, I have finished the floor and made and mounted the battery bracket today.
                          Today has been very hard, according to the forecast overcast but fine, in reality overcast with short but heavy showers. I got the gear out three times and then had to run for cover, no joke with welders, grinders and drills to protect and rescue from the rain. Ended up welding the battery box on in heavy rain before retiring wet and tired.
                          I have tried a variety of devices to remove the paint from the fibreglass parts of the body, none very successful, usually marking the gel coat. Today my neighbour offered me a little Makita palm sander to try. It worked very well even with some very worn paper installed. Five minutes and I had cleaned up half a rear wing. I would say a nice day with a good supply of paper will see the job done.
                          Not expecting to do anything tomorrow due to heavy rain forecast all day. My next target is to do a few small tasks at the front and mount a temp fuel tank 'borrowed' from a Yamaha Quad just for the MOT. I think I have the new aluminium fuel tank organised, got an eMail yesterday about it but I doubt I will be able to afford it this year.
                          The stainless front pipe has been collected from the exhaust fabrication people, just needs a short flex coupling welding into the down pipe then I can fabricate my own system. I should have the pipe tomorrow.
                          • gary.price
                            • 113
                            #73
                            I normally sleep through the early hours but the navigator keeps telling mr directions lol. Your fine once the suns up lol. When i was navigating for father we were far back in a que and fell asleep The car behind us had to get out and wake us up. Ther was only 2 cars left in front lol.
                            • Robert in Cumbria
                              • Mar 2012
                              • 603
                              #74
                              I seem to be under budget but also building to a reduced spec, just to comply with the basic MOT.
                              Just for interest...
                              • Robert in Cumbria
                                • Mar 2012
                                • 603
                                #75
                                A minor milestone, I completed piping the brake system and the fuel pipe today, will hopefully have them bled and the clutch working over the weekend. Weather permitting.
                                The exhaust is almost complete. Seem to have spent a lot of time doing very little but it's that part of the build which consumes a lot of time with not a lot to show for it. All of a sudden I will have a car instead of a lot of boxes of parts!
                                The floor panels are all made, the handbrake is finished, the radiator mountings are complete, although the radiator is leaking like a sieve, I will have to get a new core fitted or find another radiator. @ £10 a time for a rad from my local breaker that seems favourite at the moment.
                                I have discovered that my local Halfords stock GL4 EP 80W-90.
                                In handy squeezy containers I think.
                                So I seem to be on track at the moment although the dark evenings are curtailing the time I can spend on the car, I managed to work until 5 today but it was more by feel than sight! lol
