I just saw a Marlin on e-Bay that had Twin SUs AND some pancake air filters!
I then saw some 'Mini' 1.5" SU spacers that were a lot thinner than the standard ones (mine are about 25mm), and can only presume that getting the filters on was by using the thinner spacers or none at all?
So the big question is what would be the implications of fitting the thinner spacers? A bit more heat to the carbs obviously, but would it be enough to significantly affect performance?
I look forward to seeing the scoop...
