Sorted lots of niggles
  • cdow
    • 224
    1. Fitted an expansion tank
    2. Relocated the motor and got the wash/wipe working
    3. Got the straps sorted for the new folding hood frame
    4. Oiled the squeaky clutch pedal
    5. Sorted the fire-extinguisher mount to stop it rattling
    6. Tightened the rear view mirror
    7. Fitted a grommet for the water pump warning light
    8. Relocated the hazard warning light switch that kept getting kicked on by passengers (i.e. took it off and stuffed it behind the dash - I know where it is if I need it)
    9. Located and mended the broken wire for the rev counter
    10. With great difficulty, got the loom from the ECU out the way of the passenger foot well so it doesn't keep getting booted
    11. Drained the cooling system and refilled with plain water and added "Water wetter" - which makes no difference to the operating temperature whatsoever
    ***A busy day, and just one thing left which I'm not too sure how to tackle - stop the bloody drivers door popping open every 2 minutes...
