Wheel Nuts & Studs
  • cdow
    • 224
    Wheel Nuts & Studs
    Anyone know the what torque should be for Marina wheel nuts please? Can't find it in the Haynes manual and nothing online.. Also I've just fitted 10mm spacers and I think longer studs might be appropriate - what can I fit and where might I get them from?
    Re: Wheel Nuts & Studs
    Torque will vary between steel and alloy wheels?
    Standard studs are 3/8" unf. If you have spacers I would suggest fitting 7/16" unf studs from a Dolomite sprint but your wheels must be suitable for the studs and larger nuts.
    • cdow
      • 224
      It's for alloys. Are the Sprint studs longer and is it fairly straight forward to swap them? I suppose I could buy a stud & nut and see ifs okay with the wheels.
        The standard 3/8" nut on Triumph Steel wheels is 38-48 ft/lbs
        • philcoyle
          • 379
          Try www.mistertee.co.uk for studs and nuts, I've used him before and find him to have quite a selection.
          My Marina handbook gives wheelnut torque at 52-57Nm (38-42LbFT) for the car and 61-65Nm (45-48Lbft) for the van. Also toe in if anyone needs it is parallel to 1/8"(3.2mm) 0 deg 30' toe in.
          Phil
          • cdow
            • 224
            Thanks chaps.
