With fitting 17" wheels the inner wheel/tyre is very close to the anti roll bar when on full lock.
I have found a bush with grub screw that fits neatly on the steering rack behind the tie rod. All you need to do is slide the rubber boot back unscrew the tie bar off and slip the bush on to the steering rack shaft, then screw the tie bar back on then slip the bush tightly to the tie bar then tighten the grub screw. Refit the rubber boot.
The bush is 37mm outside dia 22mm inner bore and 17mm thick.
See pic for detail.
See pic for detail.
