gearbox tail end seal
  • fredsajs
    • 131
    Hi.
    Can any one advise on how to relace a tail end gearbox seal on 4 speed cortina box whilst engine and box still in car ?.
    I have trolly jack access only and axel stands.
    Also what tools are neaded ?, anything special ?.
    Many thanks.
  • CosworthCabrioLee
    • 924
    Re: gearbox tail end seal
    Hi Fred,
    Get car high enough to ease getting underneath
    Remove prop
    Put jack under gearbox and remove mount so you can Lower the box it slightly
    Drill a tiny hole into the metal part of the oil seal
    Screw self taping screw in and prise the oil seal out you may get a bit of oil
    Clean oil seal hole up
    Find a piece of tube or even a socket the same outside diameter as the oil seal and tap it into box, make sure it is square
    Examane you props haft as the part that rubs on your oil seal may have a grove in it at if this is the case it will continue to leak, 3 options 1, a new prop, 2 a spacers at the back of the prop flanges to move prop forward 2/3 mm,3 or 2/3 mill taken off diff flange to move prop back so the seal rubs on another part of the prop all of these will need machining.
    Hope this helps and makes sence if not give me a call 07720398794 and I can talk out through it
    • fredsajs
      • 131
      Hi,
      Thanks for info.
      Now have to gain enegy to do it !. Have new seal so 20% there.
      Now after 30yrs will have to see if I can loosed back axel prop shaft bolts, Will advise !.
      Fred.
