Louvres
  • dic.a.price
    • 19
    Louvres
    Hi All
    Is there anyone who knows of a company or individual you can louvre aliminium panels for my sportster? If there is could you email there details to me please i would be eternally gratefull. Near South wales would be good.
    [email protected]
    Dic price
  • bryannewell
    • 331
    Re: Louvres
    Hi Dic
    I have had two sets of Bonnet panels louvred in the last several years,both at the Marlin factories,first in Crediton and the new one just outside of town
    So I know they have the equipment,just a matter of seeing if they will do it for you!
    Worth a phone call
    Bryan
    • nigel
      • 35
      Re: Louvres
      I had mine stamped out at the factory a couple of months ago.
      Just don't accept the first price they quote you............................................... .
      Nigel
      • Robert in Cumbria
        • Mar 2012
        • 603
        Re: Louvres
        I hope to have a go at this, it can be done by hand, I have done a few test louvres and they don't look too bad. I was shown by an old hand, the tip for doing them by hand is to make an Oak block with two pins like headless nails at each end of the louvre then drill two holes at each end of the intended cut. The pins keep the metal in exactly the right place.
        Take a look at this...
        Turn the sound down!
        What beautiful work, who said skills are dead?
          Re: Louvres
          Excellent demonstration of a declining art, that sort of machinery all to often ends up on the scrap heap, and the knowledge and skills to use it, fades away, as the need declines.
          Interesting that he uses a bungee cord to support the workpiece so more recent technology still has a place for him.
          My guess is that the vast majority of current sheet metal workers would only work on flat surfaces, with digitally controlled equipment.
            • 590
            Re: Louvres
            You could try cool louvres. They used to be based in Alton, Hampshire but they appear to only show a mobile number now on the webpage. Maybe they are mobile now??
            • Patrick
              • 463
              Re: Louvres
              I used the guy in Alton, did a good job
              He's in the back corner of a workshop where they work on Pugs in the middle of nowhere!
              I had experimented with doing it myself but I was not happy with the results using a press/roller with a set of dies I made on the lathe.
              The guy in Alton uses a big press.
              http://www.modelog.co.uk/
              http://www.mustang67.co.uk/
                • 1236
                Re: Louvres
                The photo makes the louvre appear flat side up, is that correct?
                  Re: Louvres
                  Yes! Patrick deliberately chose to have them like that.
                  • cabrioman
                    • 309
                    Re: Louvres
                    I always think louvres look great but you must end up with a hell of a lot of water on the engine when the cars parked up in wet weather. I guess it might be possible to build a drainage gutter on the inside of the bonnet.
                    I might be tempted by louvres if I ever get round to replacing my Hunter bonnet, unfortunately my Hunter has visible rivets on the hinge which a lot if the Hunters don't have. I would at some stage like to upgrade the bonnet skins to the ones with a right angle bend at the hinge to allow hidden hinge fixings.
                    John
                    • Patrick
                      • 463
                      Re: Louvres
                      Yeah I wanted them that way up so the look was clean. I don't tend to go out if there's a chance of rain so it's been fine so far. Even when it has been wet I've not had any problems. Gutting is something I've considered on and off, someday I'll get around to doing something.
                        • 1644
                        Re: Louvres
                        John
                        I had a lot of water going into the air intake of my AFM and made up some gutters and drainpipes. Works a treat and even in a cloudburst keeps the engine dry!
                        See link below for my post #16 (first two photos) from way back in January 2009
                        Peter.
                        • Patrick
                          • 463
                          Re: Louvres
                          That's a very nice and elegant solution Peter
                          • cabrioman
                            • 309
                            Re: Louvres
                            Looks really good Peter, the benefit of the look and cooling of louvres without the downside.
                            john
                              • 1644
                              Re: Louvres
                              The secret is down to the magic Sikaflex! Bonds the first strip to the underside of the bonnet. The channels then attach to that with pre-fitted 3mm screws.
                              Compromise was to have a large enough crank in the gutters to maintain airflow area whilst not hitting anything in the engine bay. With the V8 there isn't much room! Peter.
