With an engine transplant in the offing I hope to use the Ford DOHC 8V Injection engine, moving up from the carb version of the engine.
As a result I am going to have to upgrade to a high pressure fuel pump. Currently I have a low pressure pump feeding fuel to the carbs, so what I would like advice on is:
What kind/brand/source HP pump others have used?
Where is it mounted?
Do you need a pressure regulator? if so what should it be set to.
Any data about HP hoses would also be useful.
Does anyone use a swirl pot?
I think I will have to fit a lambda sensor, any advice about this?
Chris
Chris
 Fuel pump - Ford DOHC Injection
