Marina gear lever
  • FranklinLeicester
    • 380
    Marina gear lever
    Has anybody got a surplus original 1275cc Marina gear lever I can have? I've never been happy with the shape of mine and I would like to make a new one.
    Franklin, Leicester
    Re: Marina gear lever
    Franklin
    Its your lucky day I have an original that has never been cut or bent.
    PM me with your details and you can have it for the cost of postage.
    • FranklinLeicester
      • 380
      Adrian, you're a gent. Franklin Woodcock, 23 Home Close Rd, Houghton on the Hill, Leics, LE7 9GT. Thanks very much!. 0116 2418183.
      Franklin, Leicester
        AFAIK there are two versions. If you end up with two different ones a photo of each might be useful for others.
          You can still have this one anyway, hopefully it will be the correct one.
            Hi Franklin I have just been in the Garage to find that the Gear Lever I was going to post to you has gone. I cant find it but I do have another as per picture.
            I am sorry but if this one will fit your needs you are still ok to have it for the cost of postage.
            • FranklinLeicester
              • 380
              That looks about right to me Adrian. Steve, I know there were 3 types of box - early, late and o/d but I was told they all had the same lever - I hope so.
              Franklin, Leicester
                The Marina was never fitted with OD as standard. That was a Triumph option that never made it into the BL market.
                But there are quite a few Marlins fitted with what are best described as hybrid gearboxes with OD, a subject discussed in detail in some of the early Pistops.
