Wheel hub studs
    Wheel hub studs
    Has anyone got any tips for getting the wheel studs out of the hubs - I need to fit longer ones due to spacer. As they are press fit I tried the high tech approach of hitting with dead blow hammer with no joy. So I assume its hubs off and find a hydraulic press. But just wanted to see if I was missing a trick.
    Re: Wheel hub studs
    I take it this is on Cabrio . I've just replaced one of the studs on mine [damaged thread] popped out with a good blow from hammer. No tricks required!
      Re: Wheel hub studs
      thanks sounds like one more try is in order
        • 1234
        Re: Wheel hub studs
        Alan,
        Put the wheel nut on each stud and then give it a good whack with a heavy hammer.
          Re: Wheel hub studs
          Cheers Danny - sounds like I just needed more weetabix!!
            Re: Wheel hub studs
            Hitting with big hammer worked thanks to all for the input - studs replaced.
