I must stop measuring things!
    • 930
    Re: I must stop measuring things!
    That sounds better. Don't forget to check for bent TCAs if you haven't already
    • Mickaleen
      • Feb 2013
      • 55
      Hi,
      Glad you are getting there Peter.
      Kind regards
      Mike.
        • 1643
        I have been busy measuring and adjusting for the last few days.
        Thanks to Mike's reminder about ride height I have now raised mine by 18mm with the front chassis now at the recommended height of 270mm. Lo and behold the front camber has changed from N/S -1.5deg and O/S 2.0deg to N/S -0-deg and O/S -1.0deg! The steering arms are now level. The extra ground clearance under the oil cooler is very welcome too!
        I can't believe how much difference the ride height has made to the camber and better still, the pulling to the left has ceased to be an issue with the car much more "planted" over any undulating road surfaces.
        Although I raised the GAZ adjustable spring pads an identical amount the car now has a very slight bias down to the N/Side since a 50 mile shake down run on Saturday.
        Further checks with a ruler tomorrow to see if I can get it completely level, followed by another camber check before shimming the O/S top wishbone mount in search of perfection -o- deg both sides!
        The ongoing plan is then to sort the rear ride height with inevitably more measuring!
        Peter.
          You;ve started me off. Measured the Roadsters (a Hybrid) ride height through wheel centrelines to 'wing arch' returns yesterday and noticed the car is 2cm higher front left and rear left! I have two NOS rear leaf springs for a 1.3 Marina so will swap thous in before doing anything else. I suspect the car has just settled that way after 28 years of driver only travel.
            • 930
            #20
            I would measure the chassis to ground clearance rather than relying on the wings being mounted perfectly.
              Worth considering Superflex bushes for the springs and hangers, there is also a leaf pad but it requires trimming.
              There are 12 different variants of rear springs available, luckily the vast majority are two leaf from the 1.8 and 1.3 Marina Saloons but they used different ratings. Unless the springs are clearly marked, you wont know which you have. Info here or there.
              From experience removing the shackle nuts can be problematic. They are exposed to all the salt and elements, and without soaking thoroughly with a release agent the chances are that one of the 8 shackle threads will shear, so worth having a couple of spares handy along with nuts and washers etc. before starting work. Available ex-stock from Earlpart but other cheaper suppliers are available.
                Yes I will do that. What kicked it off was noticing the left front wing appearing to be higher than the right so I went there first. If the chassis is level then I'll have to refit the panels, which means waiting until I get the respray funded. (although currently considering a quick fix with a vinyl wrap, could be all done for £200!)
