Clutch Problems
    Clutch Problems
    Message originally posted by: David Price
    The clutch on my Roadster has got to the point were it does not disengage. When I press the peddle the slave cylinder is pushing the lever until it is almost touching the side of the bell housing. I think the problem is probabily with the thrust plate rather than the clutch plate? Any idea's and were is the best place to buy a new clutch kit and what is the part number?
    Re: Clutch Problems
    What is the donor?
      Re: Clutch Problems
      Silly me, my Roadster is based on a 1800 Marina cira 1975.
      • almyland
        • 118
        Re: Clutch Problems
        I just visited my local motor factor here in Peterborough and got an exchange unit for ?35; that's the complete kit. My car is based on an Ital but I'm sure they had a kit for the Marina. The replacement had Borg and Beck stamped on it although I'm sure they did not produce the kit. Works just fine. Hope this helps.
          Re: Clutch Problems
          you could try http://marina.spares.me.uk/steve.html. Never tried him myself just a link I've picked up.
          I have seen Marina clutches somewhere, but I can't for the life of me remember where! I'll personally try my local motor-factor when I need one though.
            • 590
            Re: Clutch Problems
            New EBC (same as brakes) clutch kits available direct.
            http://www.ebcbrakesdirect.com/car/parts_clutch.asp?part=clutch&make=ROVER&mo del=Marina&year=1%2E8+%2871%2D80%29
            WARNING! Do not buy a Quinton Hazel clutch. I have had 2 fail on me in the past.
            Hope this helps
            Jon
            • CABRIOBOB
              • 478
              Re: Clutch Problems
              I bought one for a Marina 1800 from Partco ltd (unipart) for ?70.00 kit LUK622038800. Also try www.earlpart.co.uk part no CL0202 ?70.00 EXCHANGE. They are Marina spares specialists..........Bob
                Re: Clutch Problems
                Also lots on ebay......
