steering uni joint
  • Dbdelboy
    • 43
    steering uni joint
    what is the best way to replace the steering uni joints on serria based car? the center rod has welded uni joints, top one bolted on.
    Re: steering uni joint
    you should be able to get what you need from CBS, they have all the parts for sierra type steering columns including bolt on and weld on ujs
    • Dbdelboy
      • 43
      thanks will try .
      • scott h
        • Mar 2013
        • 670
        rallydesign.co.uk also do UJ's etc
        BURTONPOWER.COM also including the rubber disc coupling.
