Clear U profile ?
    Clear U profile ?
    Does anyone know where I can buy a couple of metres of a clear (opaque) U profile to fit over the tops of my side windows in order to pass the IVA test?
    The glass is 5mm thick.
  • CosworthCabrioLee
    • 924
    Re: Clear U profile ?
    Mike shower screen seal £9.99 b&q
      Is this a soft profile?
        No idea if its pliable but use a heat gun gently!
        • CosworthCabrioLee
          • 924
          Yes Mike
            Bet you could get Mike a discount Lee
            • CABRIOBOB
              • 478
              Homebase will be cheaper............
              • Peterx
                • 361
                Halfords do a clear u profile door protector....... might be worth checking out if it's flexible enough?
                • cabrioman
                  • 309
                  Does it need to be clear? There are lots of kitcar trim suppliers that can provide u channel rubber in black. It might not look great but there is a strong chance of it blowing off in the wind after IVA.
                  John
                    • 709
                    CBS do a chrome version which might look better than black...#TRMCU5 is the part no.
                      This is the conclusion I came to too: if it looks permanent the examiner has less reason to reject it.
                      I bought some from Woolies Trim today for £4, - its not ideal as it really suits 2mm panel thickness not 5mm, so is splaying open a little, but it looks reasonably permanent:
                      - though as John says, it will still probably blow off in the wind on the way home!
                        nah, that'll never come off
