Rubber trim to edge wings
  • keith_h
    • 549
    I want to look at edging the wings on my Roadster with some sort of rubber trim. I don't want it to be too thick. Those of you who have recently gone through SVA etc what did you use and how did you handle making it look good on the corners - is there a product that can be stretched so that it doesn't wrinkle?
    Re: Rubber trim to edge wings
    keith
    I have edge trim fitted to the wings on my Cabrio [done by previous owner for sva] At the moment I have no idea where it was sourced from but I have a section spare of about a foot long I can send you for reference if it helps. It is pliable enough to go around corners without mitreing which is ideal.
    If you Pm me your address I'll post on if you wish.
    Will also check my file of receipts to see if I can find supplier.
    Alan
    • philcoyle
      • 379
      try www.thamesvalleysupplies.co.uk for rubber channel
        Originally posted by dogoncrazy View Post
        keith
        Alan
        Hi keith
        The profile Alan has can be obtained from Woolies trim:
        Fast same day despatch of door seals, rubbers, window channel, weatherstrip, edge trims, sound deadening and lots more. Providing excellent customer service for over 40 years.
        • keith_h
          • 549
          Thanks guys.
