Does anyone know which bowden cable is used for the LWB doors using the Marlin Galvo door panels with the elbow recess. I took over the build of my car and it already had the door locks and bowden cable fitted to the door with the interior door handle connected to the cable. When I have come to fit door panels I realised the cables were too short to reach the mounting in the Galvo panel. Trouble is I am not sure if the existing cable is from the Sierra front or rear door, I obviously need the opposite of what I have but I don't know which I have fitted.
Sorry if this all sounds a bit confused, basically is it the front Sierra door cable or the rear that should be used for the LWB doors using the Marlin Galvo panel with the elbow recess.
Any info most appreciated, its a real shame you can't just turn up at the breakers and wander around to find the bits you need as you used to be able to. It made things like this a damm lot easier to resolve.
