Cylinder heads-
  • djj_engineer
    • 405
    Cylinder heads-
    MGB/1800 complete with valve gear
    Duplex camshaft drive chain wheels
    Rover V8 heads complete with valve gear
    And more call me before it all goes to the scrapyard.
    Also MGB O/d Gearbox
    All to be scrapped 2nd week in Jan 2014
    Now the 3rd week in Jan So all scrapped.
    Re: Cylinder heads-
    Perhaps we are too late.
    The duplex camshaft drive chain wheels, especially if the chain and tensioner are included, are a rapid upgrade as it all fits under the standard Marina timing chain cover.
    I have rarely heard of a simplex Marina timing chain failing, but if you have plans to change the cam with a higher lift one, the load on the chain increases.
    Having said that with a new cam I would always fit an adjustable sprocket to get the particular cam set spot on.
