Indicator mount ideas
  • CompoSimmonite
    • Jun 2013
    • 318
    I don't like the normal motorbike type indicators so am looking at alternatives.
    All I can come up with is the Caterham mounting brackets that fit under the headlight and take Land Rover items
    • 709
    Re: Indicator mount ideas
    You could try motorcycle headlamp fork mounts set horizontally around the front bumper bar...and get a nice pedestal unit to fit...or weld a bracket on...or tap into the bumper bar directly.
    For wing mount why not try S-V-C who do Lucas pattern torpedoes which contain side & indicator units.
      • 905
      I have converted my wing sidelights to indicators by fitting 21w orange bulbs and a clear lens. I also fitted side repeaters fixed to a bracket mounted to the two top forward wing mounting bolts. It has passed MoT four times with these and I do ask the tester each time if they are happy with the arrangement.. I have the sidelights inside the headlamps but take care that they are less than 400mm from the outside edge of the car as that is the maximum distance allowed. I have not put anything in the open space left by chucking the motorbike indicators.I may fit tiny torpedo sidelights but have not decided yet.
