the pedal box I had from marlin for my BMW build is for a side mount clutch master cylinder rather than the more common flange mount. Does anyonr know what cylinder this is please because i need one!
Tags: None
Re: clutch master cylinder
bmw clutch master cylinder as out of 320/325i 1977/1987 it fitts horizontaly above clutch pedal with pipe to slave cylinder facing towards drivers seat it will require two spacers approx 50mm long to line it up with pedal.You can also get a remote fluid reservoir combined for clutch and brakes
What remote reservoir do you use with this master cylinder? - and what model car does it come from?
Peter
Do you have a contact number for Car Builder Solutions?
regards
