Hi guys
Back in November last, I started a thread about rainwater entering my Hunter's interior (beneath the dashboard), and with some help from members I thought I had tracked down the source in front of the windscreen wiper area. I cleared the slot either side of the battery, plus the usual leaves and junk, and for good measure installed a pipe to take away water from this area should the slot get filled with junk. Also, I applied quality exterior gun-sealant around all of the various nuts & bolts after thoroughly drying out the territory. I thought this amount of work had nailed the problem, and the odd shower made no impression.
Maybe it's not that surprising with all of the recent rain that we have experienced, the leak has recurred: on the both sides of the central console. No great amounts, but a bit niggling all the same. I plan to remove the bonnet and the cover over the wiper area again, and check that the sealant hasn't come undone. Before doing this, I thought it worthwhile to ask if anybody has any other ideas. Your help would be appreciated.
