Marina gearbox with overdrive?
	Tags: None
Re: Marina gearbox with overdrive?
That's a useful find. Especially as the clutch slave bleed nipple is at the top.
presumably the gearbox is either a triumph or marina 1.3 gear ratio, either way its worth checking with the seller as many Triumph and all 1.3 Marinas had fewer splines than a 1.8 Marina. Not too much of a problem sourcing a clutch plate, to adapt between the two though.
