Marina top ball joints
  • petermarlin1798
    • 21
    MoT failure on one, excessive play. Having dismantled it, there seems no wear, so can I just tighten it up? The rubber gaiter is slightly split so that may be a failure anyway. The build manual says that a Mk II ball joint must be used. What is the difference between that and the Mk I version? Earlparts only list a Mk I balljoint.
  • petermarlin1798
    • 21
    Re: Marina top ball joints
    Just got a repair kit on ebay for not much, so should solve the problem.
    • philcoyle
      • 379
      Hi Peter
      I thought that the top ball joints were shimmed up and you could adjust them by adding or removing the shims.
        Maybe different size taper, fairly sure no shimming possible.
        • philcoyle
          • 379
          If my grey cells are working I seem to remember that the ball sits on a strong spring in the bottom socket that is screwed to the leg. The top cup is screwed on to the socket and adjusted with shims and the locking tab and this gives you the amount of movement to the ball joint.
          Just had a thought we are talking about marina leg fitted with mini top ( wishbone?) and ball joint are we?
            Think you are right Phil. I put mine together back in '92/93 so memory isn't what it once was.
              The only shim as such is the locking tab. Once the joint is dismantled and cleaned check for wear. Re assemble with grease then adjustment is by tightening down the top retaining nut with the locking lower nut backed off until resistance of about 40lbs/ft to move the pall pin on its full articulation. Then the locking nut is tightened back to the top nut at 70 to 80lb/ft the locking tab preferably a new one is bent down one side and up the other to lock the assembly. Be careful if you rebuild with the old pin as if you take out the slack at the local wear point in the middle range the joint may seize at extreme movement and cause a failure.
              • philcoyle
                • 379
                This should help clear things up E bay 191139651594 mini top ball joint with lock tab and shims, without shims how can you obtain the necessary loading on the ball joint?
                  • 590
                  Phil,
                  Those are for a Mini that you have found on eBay. We are talking Marina / Ital MK11. They are different from the Mini. The Marina ones work as per Ben's post above.
                  See eBay http://www.ebay.co.uk/itm/TOP-BALL-J...item3ce0317113
                  Jon.
                    Hi All
                    I hope the extracts below help.
                    • philcoyle
                      • 379
                      Oh well, it just goes to show what a bodge up the person who had the car before me made of the front end. I had fitted Walford trunions and superflex bushes to firm up the front but in the end!
                      I built my own unequal wishbone front suspension for the car with coil overs. I went in the garage today and had a look at the old Marina suspension and yes it does have shims under the locking tab so well done Mr original builder, it goes with the speedo cable that was shorting out on the dashboard wiring, and the way dissimilar materials were bolted together with plain nuts and bolts, plus many other bodges that I found on the rebuild.
                        Hi Phil
                        Don't get to despondent.
                        • philcoyle
                          • 379
                          Hi Adrian,
                          I'm not despondent, all that happened years ago but it would appear that certain things trigger off memories and then you wonder if you really are getting past your sell by date.
                          In the time I have had the car I have modified it, 2.8 Capri LSD back axle, track and body widened by 8 inches, coilover and wishbone front suspension and Cortina uprights, EFi 2.0ltr engine, type 9 gearbox with concentric hydraulic clutch, wire wheels with hub adaptors, aluminium tank with intank pump, and on and on and on.
                          Keeps the old grey cells well stretched.
                          Phil
                            I sympathise...I am rebuilding a lwb roadster and am lucky in that it has been put together really well...or was it? I'm not saying its been done wrong, just I would have done things differently. In my own case I am thinking that some jobs were a bit rushed and full thought not given (like the myriad of tiny slotted screws holding the gear lever plate in place, or a bar behind the rad being just low enough to touch the bottom hose, or the fuel filler pipe clip resting on the negative battery terminal. In my case, little details which will take an eternity to remedy but then again, back in the day people just wanted to get out onto the road in a car they had made themselves. Maybe IVA isnt such a bad idea after all?
                            • philcoyle
                              • 379
                              Cameron,
                              I think IVA is a life saver in many ways, just as the MOT at present helps to keep some of the shall we say unmaintained vehicles due to insufficient funds or basic car repair knowledge, off the road.
                              Kit cars are all about being the individual, of putting down your thoughts on how the car should look or sound and the big grin on your face when it all comes together. It doesn't matter what other people think it's yours and everyone else can lump it. The time it takes to do things your way, irrelevant, so lime green and pink doesn't appeal to everyone but if we think so then so be it. It doesn't matter what badge is on the front of the car, the thing is it's your badge.
