Marina based Roadster Steering
  • charles44
    • May 2014
    • 60
    Hi
    Having liked the look of Marlins for longer than I care to remember and have (at last) just picked one up.
    I have noticed that the top rubber steering joint is starting to crack - would someone point me in the direction of the origin of this part?
    Many Thanks
    Charles
    Re: Marina based Roadster Steering
    Not sure what part you mean?
    On the suspension, rack, or steering column?
    Do you mean this?
    Triumph 2000 steering joint
    Steering Shaft Flexible Coupling Rubber
    OEM part number 21H5384 Equivalent Triumph part number 150696
    Order your Steering Shaft Flexible Coupling - Rubber - 150696 ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
    • charles44
      • May 2014
      • 60
      That's the one (and ordered using the link)- many thanks!
        Can I suggest a look at http://www.fastmarinamagazine.com/in...c6fe1eae1b98e2
        you might find something else of interest there.
